Ranger Tech (2019+)
Ranger Tech ('83-'11) Product / Build Guide Other Articles TRS Events Overlanding Readers Rangers
Discussion Forum
TRS Store
Ford Ranger 2.3L Electronic Thermostat - By White001
Trucks Of The Month
Shirts & Decals
Click to check out our TRS Store
Ranger Buyers Guide
2002 Ford Ranger 2.3L 4-cylinder p1432 code
I had this code on my Ranger. The dealer charged me $130.00 to tell me it's the electronic thermostat and wanted $500.00 more to fix it. I located one on Ebay and put it on myself for about $110.00. After I got the new one installed, the auto parts dude reset the check engine light and I was good to go. I inspected the old unit and sure enough, the little tiny connectors on the wire plug looked fried and black. I had to remove a keeper clip to pull that wire connector out for inspection.
So based on my experience if you're getting P 1432 code and a fried connector, it may be time to replace the electronic thermostat.
Also of note is that I purchased a 2001 2.3 Ranger thermostat. The folks that sold it said it's the same part, so I trusted them and It's working well so far.
After closer inspection it looks like I broke the wires off a thermistor coming out of the thermo housing. It appears that the thermistor is imbedded in epoxy and it's fried to a crisp.
The 2001 and later 2.3L engines has a thermostat that is part of the housing. The thermostat and housing is replaced as a unit. It can be located by following the LOWER radiator hose down to the engine block.
footer
Advertisers
The Ranger Station
   About
   Staff
   Contact Us
   Advertising
   Legal Notices
   959 Media LLC
   Copyright © 1999-2020
Submit Content
Have Info To Share?
We're always looking for good content to share with other Ford Ranger enthusiasts. Click on the 'Submit' button to find out how you can get your submission posted and acknowledged for it.
