Ranger Tech ('19-'20)
Ranger Tech ('83-'20) Product / Build Guide Other Articles TRS Events Overlanding
Readers Rangers
Ford Ranger Forum
TRS Store
Grunizzle's 1991 Ford Ranger 4x4 AKA 'stRanger'
Trucks Of The Month
Ranger Buyers Guide
We love the factory color and STX stripes of Grunizzle's 1991 Ford Ranger 4x4. The combination of the factory colors and the blue James Duff suspension and black wheels makes for a nice looking 4x4.
Don't let the 'nice looking 4x4' comment mislead you though. This is a very capable off-road rig.
Here are the specifications:
1991 Ford Ranger STX 4x4 Extended Cab
Engine & Transmission:
  • 351W V8 (with GT40 intake) from a 1989 Ford Bronco
  • Engine bored .30 over / Keith Black 11:1 pistons
  • 1.7 roller rockers
  • Comp Cams Extreme 4x4 cam
  • Small block ford header builders kit. I got 3 inch collectors, a ton of bent up 1 5/8" tubes, header bolts and gaskets
  • Ford C4 automatic (has the atlas adapter and 27 spline output) with Dana 300 transfer case and Behemoth Drivetrain Doubler
  • TCI heavy duty towing torque converter
  • B&M shifter
  • Twin sticks on the transfer case
  • Suspension:
  • Skyjacker 6-inch leaf springs and Belltech shackles
  • 12-Inch Bilsteins at all corners
  • Custom upper rear shock mounts
  • James Duff 78-79 Bronco radius arms
  • James Duff 5.5 early Bronco coils
  • James Duff panhard braket
  • James Duff SAS coil buckets and HD lower coil retainers redrilled 3/4''
  • Knuckles and pitman arm reamed for Ruff Stuff steering kit
  • Axles:
  • Ford Explorer 31-Spline 8.8-Inch rear axle with 4.56 gears and Detroit Locker (wheel adapters to match front wheel bolt pattern)
  • Fullwidth Dana 44 front axle with G2 chromoly shafts, 4.56 gears and Grizzly locker
  • Ruff Stuff diff cover
  • Tires & Wheels:
  • 37x12.50 R17 Goodyear MTR Kevlars
  • Procomp 17x8 wheels with 4.5-inch back space
  • Other Features:
  • 2-Inch body lift
  • Toyota Extended Cab 80-inch sliders from 4x4 Innovations modified to fit
  • Custom bed / cage
  • Custom bumpers
  • Smittybilt XRC8 winch
  • Jaz 22 gallon fuel cell
  • Summit fuel filler kit
  • Holley in-line fuel pump
  • Jegs pre pump filter
  • Sony Xplod ipod deck
  • Custom gauges
  • More Photos:
    (Behemoth Drivetrain Doubler)
    (custom gauges)
    (custom console with B&M shifter)
    (Monstaliner on floor)
    Links:
    Grunizzle's stRanger (Click for more photos and details)
    Monstaliner
    footer
    Advertisers
    The Ranger Station
       About
       Staff
       Contact Us
       Advertising
       Legal Notices
       959 Media LLC
       Copyright © 1999-2020
    Submit Content
    Have Info To Share?
    We're always looking for good content to share with other Ford Ranger enthusiasts. Click on the 'Submit' button to find out how you can get your submission posted and acknowledged for it.
