White wire has continuity from #2 and #3 to PCM connector. Only OBD codes I am getting is from deleted ERG, 335 and 558.
Probe light on white at #2 and #3 injector connected to battery (+) does not flash. Stobes when hooked to #1 and #4 while rough idling, like a NOID light.
Originally cut out when driving, lowered rpm and they came back on, then out again with rpm increase, then just stopped pulsing completely.
Swapped around injectors, #2 and #3 work when installed to #1 and #4. Swapped between 2 ICM modules, no difference.
Failing PCM, or crank sensor? Replaced crank sensor 3 or 4 years ago, but when the old one was failing it was a complete no start. Confirmed spark on all plugs.
