View Single Post
Old 07-16-2010, 10:00 PM   #3
disciplerocks
July 2011 OTOTM Winner
disciplerocks's Avatar
Year: 1989, 1991
Make: Ford
Model: Bronco II XLT, Ranger XLT
Engine: 4.0, 2.3
Class: 4x4, 2WD
Used For: the rippin and the tearin
disciplerocks is a splendid one to beholddisciplerocks is a splendid one to beholddisciplerocks is a splendid one to beholddisciplerocks is a splendid one to beholddisciplerocks is a splendid one to beholddisciplerocks is a splendid one to beholddisciplerocks is a splendid one to behold
Default
Here is the most recent updates.
Got some new rims from John (railman).
And here is what I am currently working on. Going to try to push 15 psi now. In order to do this I got new 42# injectors, an IAT from a Lightning for more accurate intake temps, 5.7" crank pulley, and what was supposed to be a 2.3" supercharger pulley.
Since I am going to be pushing the sc pretty hard, I decided to change the oil in it.
Now as of right now I have the larger crank pulley on and pushing about 12 psi. The sc pulley ended up being the wrong size, so I am working on getting something worked out on that. I went to the u-pull and bought a core alt from them for $7. The pulley on it is the exact size I need. Now I am going to take it to work and have the keyway machined.
__________________
89 Bronco II XLT: 4.0, A4LD/5R55E, 1354 Doubler, 35" Baja Claws, XJ coils, FW HP44, Tru-Trac, Spooled FW 8.8 Disc Brake, 4.56s, OBA
91 Ranger XLT: 2.3, M5OD, Dream Beams, 31 spline 8.8, Rear Discs, Limited Slip, 3.73s
04 Focus ZX3: 5.0, T5, 4 lug 7.5, Rear Discs, 3.73s
12 Focus SE: Sport & Winter Package, ST Front End
Quote:
Originally Posted by AllanD View Post
Ford says (about towing not masterbation) "Don't do that!"
disciplerocks is offline   Reply With Quote
