Air bag (no key turn off)
Hondafreak08
Dayton, ohio
ok so heres the deal.. A friend has a 96 ranger, extended cab. 3.0.. Shes about to have a baby and needs to put it in the front seat.. airbags can kill the baby,, yada yada...
the thing is she doesnt have a way key to turn off the passenger airbag like most newer rangers have...
what is the easiest way to turn off the passenger bag.. is there a way involving pressing the gass brake turning ignition on and off ect ect... (like when you turn off the seat belt chime.. or is there a fuse or something to disconnect)
thanks for your help
(yeah i searched)
schneiderz
Alpharetta GA
2.3 4 cylider
Ya you just have to go into one of your fuse boxes. One should hve a fuse for the airbag just take out that fuse and you are good to go.
Hondafreak08
Dayton, ohio
ok does it disable both of them or one?
schneiderz
Alpharetta GA
2.3 4 cylider
depends on the car it might disable both but knowing ford you might get lucky and it will only disable the one
Ranger Sport Honduras
Zoom Zoom
197
Honduras
Mitsubishi/Ford
3.0/2.3
Fortune Favors the Brave
that will disable both and might turn the airbag light on. when that goes on it will come with an annoying chime everytime the truck is started.
u sure 96 had both airbags?
snomaker321
mass
4.0 SOHC
my '96 didnt have a passenger airbag...im pretty sure if theres no swith then theres no passenger airbag
Zoom Zoom
197
Honduras
Mitsubishi/Ford
3.0/2.3
best option is remove the cover and check if it has an airbag. i think that was optional. on that year.
