Fuel gauge fluctuates
TIGGER
Beaverton, Oregon
The fuel gauge on our Explorer has been acting up for the past month. Upon startup the gauge can fluctuate to from pegging E or pegging F or to the normal gas level. If upon startup the gauge pegs to E or F it will eventually read the proper fuel level in the tank if the trip is long enough. Has anyone had a similar problem? Any help would be appreciated.
289-tiger-
What year Explorer do you have? I have an 05 with intermittent readings and CEL (P0463). There is a TSB on its issue for 04 to 07 Explorer and Mountaineers.
Good luck
TIGGER
Beaverton, Oregon
Sorry it is a 91 with an A4LD.
289-tiger-
No problem, hopefully someone will have a suggestion on the 91 and will not be the sending unit.
Good luck
Ozwynn
200
Berrien Springs, MI
RE Interceptor
If you can't go through it or around it, then go over it.
sticking float? I had to replace the guages and the tach and speedo rebuilt in my 91 sploder. they died from old age.
TIGGER
Beaverton, Oregon
I don't think the float is sticking as the gauge pegs to E or F upon startup and then after a little while driving the gauge will slowly read the proper fuel level. Sometimes it reads the proper fuel level upon startup but it is rare now.
