taillights not working.
daveguy
chilliwack bc canada
mazda b4000
so my taillights wont work and the manual doesnt tell you shit about wiring and were the rear taillights main power is. k so my signals,brake lights and reverse light all work, even my licence plate lights work. but my rear taillight wont come on. any ideas
thanks dave,
BRUTUS_T_HOG
ASE Certified Tech
36
Rainier, OR
2.3L
so neither taillight works? first be SURE the bulbs are not just burnt out before wasting time.
then trace the wires from the license lights back to the harness plug and wiggle it and see what happens
eclipse2001gt
Atlantic,Iowa
Ford,nissan
2.9,5.0,7.5
Check the light switch to see if you burned it out. had that happen in another b2 that i owned. Did it twice and ended up replacing the plug it connected to since it melted the plug on it from the light switch getting to hot.
Had the same problem where the tail lights would not work but every thing else would work.
Earl43P
38
Farmington, Pa
Ford F250 4WD
feellnfroggy
28
Knoxville, TN
This happens with alot of early rangers I ve heard of, MIne did it and I lost all brake lights unless the parking lights were on. I had to replace the switch and pigtail. But check fuses too. most likely the bulb are burned out because the circuit still works.
daveguy
mazda b4000
well got it all working. the rear crossmember was tugged on and ripped in half before i got it and i couldnt see any ripped wires but i searched for awhile and there was so i connected the split wire and i had one light on. so i got it off the houst and took the bulb out and checked the plug for power and i saw there was corrosion so i scratch it abit and poof! i had power, so i vasaleened the bulb up and stuck her in. i got lights now.
thanks yall,
chadmilliser
MOIRA NY ( 5 MILES AWAY FROM ) CANADA
FORD
not to sound redneck .. mine messed up and what i did was togo switch the taillights... its funny at night time when somones right on your butt you can shut them off and they back off. :icon_rofl:
scottclark24
my signal lights and brake lights work but my taillights don't work.what do i need to check?
Earl43P
38
Farmington, Pa
Ford F250 4WD
Look for power on the Brown wire coming out of the headlamp switch (in Park/Head positions). No power on BN wire = bad headlamp switch.
Front left, front right and rear each have their own seperate ground, so it's NOT a ground.
If you've only lost the REAR parking lamps, start at the connector at the center of the rear of the bed, check BN wire for 12v. If that is good, clean the ground, G200, located below the fuse panel on the driver side of the dash, may be under the kick panel / parking brake.
There may be a parking lamp relay in the fuse box, under the hood, slot #13, but ONLY IF you have remote keyless entry.
Swap it with the washer pump relay in slot #14.
ja8008
I have a 1994 Ranger supercab 4wd. I only have working brake lights when the headlights are turned on. Connection and wires check good. Bulbs are new. Any ideas what might be wrong? I feel like I'm overlooking something.
Spott
21
SE Idaho
You need to start your own thread about this issue.
ja8008
I figured it out. The guy who had this truck before me wired the headlight switch wrong.
Does anyone have a pin out for the headlight switch for a 1994 ranger 4wd supercab?
Sent from my SAMSUNG-SGH-I317 using Tapatalk
ja8008
Original socket for headlight had a burn mark and two pins were not seating right. Some of the pins were broken and weren't making contact properly. So, I replaced the socket with pins and wire. Now I have brake lights working properly.
LynnB
NoVA
thanks dave,
Update on taillights not working:
So I had the same situation as Dave: all lights on the 1991 Ranger working except the taillights and license lights. Checked bulbs and both were good. The taillights are on the same fuse as headlights, meaning there is no separate fuse to check. If you have headlights you should have taillights. So the problem was either in the light switch or in the wiring. The hot lead for 1991 is brown.
Replaced the switch and did not fix the problem, so began to inspect wiring harness. Found a broken brown wire under the bumper. Once it was spliced up it solved the problem for both taillights and license plate lights.
Kirby N.
March Truck of The Month
