Stock Tire Size
Memphis
Knoxville, IA
2.3
What should be the stock tire size for my 1994 XLT 2.3,5spd, 2wd? I currently have some so-so P225/70R14 tires on there now and with Winter coming up I need to find some better ones. Unfortunately, probably used ones at this time......or chains......
Original_Ranger84
20
2.8L, 3.0L
A 215/70/14 is probably the stock size tire for your truck. I would definately invest in some chains as well they are lifesavers!
koda6966
61
The green part of NY.
It should be listed on your door tag.
Memphis
Knoxville, IA
2.3
Can I put a different size tire on these rims? Not very different, but maybe....P195/70R14.....or.....P215/70R14? Would different size back tires be bad? I assume width would not be an issue just heigth.
trailbikerider
Kalamazoo, MI
Your stock tire size is 225/70/14, says so on the driver's side door jamb. I am running 215/70/14 Firestone Winterforces for the winter, and it makes the speedo read maybe 1 MPH slower than it should? Check this website out, and plug in the two tire sizes, and it'll tell you the percentage your speedometer will be off.
http://www.1010tires.com/tiresizecalculator.asp
Original_Ranger84
20
2.8L, 3.0L
Since I assume you have a 2wd with 14" rims you can put different sized tires on the front and back. I have heard both ways that a narrow or wide tire is better on ice. A skinny one will concentrate the weight on a smaller spot and allow the studs to dig into the ice better where a wide tire would help keep the truck above the snow.
Kirby N.
March Truck of The Month
