How Many miles before change Timing Chain?
mlunsford
Off Road
4.0 OHV
Can someone tell me how many miles I should go be before changing the timing chain on the 4.0L OHV engine ?
Thanks!!
exbass94
39
Guilford, CT
4.0 SOHC, 4.0 OHV
You never have to replace it. Keep it in there till the engine dies.
mlunsford
Off Road
4.0 OHV
Thanks,
I have my heads off (cracked) changing my water pump. only 104K miles. Do not really want to change the timing chain.
Thanks for info !
AllanD
134
East-Central Pennsylvania
1987... sorta
'93 4.0
I've seen the factory timing chain go 250K plus in 2.9 engines
The very similar timing chain setup in the 4.0 has a better tensioner design and the chain is under less stress, because to spin the cam in a 4.0 takes only 30% as much force as the one in the 2.9.
Sound strange? Two word for you: "Roller Cam"
There is NO reason the timing chain in a 4.0OHV to EVER wear out.
AD
Big Jim M
30
Austin
My 08 Chevy came with a paper that sez the chain has been tested to 200K and is expected to NEVER need changing.. WOW!
Big JIm
shadetree
9
East Texas
Explorer Sport
The worst case of a timing chain problem I ever say was on a 1977 Chevy V6. The chain had stretched so much that it wore a hole in the upper and lower side of the timing cover. Oil everywhere, but it still ran ok. Owner would just dump in a bunch of oil, and take off. :)shady
mlunsford
Off Road
4.0 OHV
Thanks Allan
Thanks for info Allan.
