how do i know if i have 4 wheel abs or rear only
jandm
i need new front rotors asap, is there an easy way to tell if i have 4 wheel abs or rear only, any help would be appreciated. 96, 4x4, 4.0
jandm
Quick assistance would be very helpful i have to go soon for a mmeting and i need the answers ASAP It would be GREATLY appreciated...
Jspafford
Logan Andrew Feb 17, 2012
15
Lancaster, Ohio
Chevy 3500HD
6.6L
5"
1996 was the first year they offered 4WABS, so depending on when your truck was manufactured, it may or may not have it.
If you give a dealer your VIN# they can check for you.
If you have a 2.3 or 3.0, it is RABS only, if you have the 4.0L it has 4WABS.
jandm
thanks i will call the dealer today.
AllanD
134
East-Central Pennsylvania
1987... sorta
'93 4.0
IT's easy enough to look underneath and see if there is a cable in clips that runs along wiht the caliper brake hose.
Failing that the ABS pump is kinda obvious uder the hood of a '95-up Ranger.
And for the record I've seen 1994 rangers with factory 4WABS.
On the 4.0 supercabs I believe it was standard starting in 1995.
BTW, Ihave 1995-97 beams on ym truck to get the two piston calipers
and I had an absolute devil of a time getting a NON-ABS Left front brake
hose when I was putting my Ranger together.
there simply was NO LISTING for a non-ABS '95 or '96 Ranger.
I finally found a listing at NAPA for a 1997 without ABS.
AD
AD
