how to set timing in a 2000 3.0 ford ranger
RRTDiesel
how do you set the timing in a 2000 ford ranger with 3.0 l v6?
Sasquatch_Ryda
Forum Staff - Retired
108
Terrace, BC, Canada
Solid Axle Swap 4x4
40s
You don't. The PCM does.
RRTDiesel
so it will set itself?
stegomon
20
auburn/minot maine
fords and only
i think you could set it by the timing chain
TomB1269
Capital District NY
2002, 2005, & 2
All Fords
3.0L/4.2L/5.4L3V
Yup, the computer controls the timing curve to meet fuel needs at given temp, and humidity......... When you change your plugs or replace a sensor you should disconnect the battery (negative cable will do) and let it sit for a few minutes to reset the ECM/Computer.
McCormack
8
You need either a chip or a tuner to change the timing. I've got an SCT tuner and I program the timing that I want on my home computer and load it into the SCT, then I take the tuner out to the truck ('00 Ranger) and flash the truck's PCM.
Kirby N.
March Truck of The Month
