Serving Ford Ranger, Bronco II, Explorer & Mazda B-Series Owners Since 1999
Home Forums Info - Technical Info - Other TRS News Photo Galleries Shirts & Decals Parts Store Classifieds
Go Back   The Ranger Station Forums > Engine & Transmission Forums > Transmissions
Notices
Post New Thread Reply
Thread Tools Display Modes
Old 04-23-2012, 08:27 PM   #1
mindlessdrone
Year: 1985
Make: Ford
Model: Bronco II
mindlessdrone is on a distinguished road
Default What transmission will work best?
I have an 85 Bronco II that I am putting a 88 302 HO into. I am putting a 3 inch body lift with a 4 inch suspension. What I need to know is, what manual transmission with 5 speed will best fit in the Bronco II? Will I need new drive shaft and will I need a new cross member or just relocate the cross member? Also any other info about it. I don't want to do any major changes or modifications if possible. Thank you for any info.
mindlessdrone is offline   Reply With Quote
Old 04-24-2012, 08:50 AM   #2
projectnitemare
projectnitemare's Avatar
Year: 1988
Make: Ford
Model: Ranger XLT
Engine: 396W
Class: 4x4 Extreme
projectnitemare will become famous soon enoughprojectnitemare will become famous soon enough
Default
The best fitting 5 speed for a V8 will be the M5OD-R2 used in the F150. Not a bad fit, will hook up the your existing clutch hydraulics if you have them but required a fullsize t-case. Look for an NP 208 or 205 they are the smallest, mid 80's and oldeer trucks. You are guranteed driveshaft modifications and will have to move the crossmember. You should be able to move your factory one and use it again.
Matt
__________________
88 Ranger XLT 4x4, no drivetrain, no frame, nothing....new stroker, frame and drivetrain in the works
projectnitemare is offline   Reply With Quote
Old 04-24-2012, 08:57 AM   #3
alwaysFlOoReD
Super Moderator
Year: '91, '85, '97
Make: ford
Model: ranger, b-II, f-150
Engine: 4.0,4.0,4.2
Class: 4x4 race, 4x4, 2wd work
Used For: 4x4 race, 4x4,2wd work
alwaysFlOoReD is a splendid one to beholdalwaysFlOoReD is a splendid one to beholdalwaysFlOoReD is a splendid one to beholdalwaysFlOoReD is a splendid one to beholdalwaysFlOoReD is a splendid one to beholdalwaysFlOoReD is a splendid one to beholdalwaysFlOoReD is a splendid one to behold
Default
I've read the m5od-r2 from the f-150 with the 4.2 liter works best for shifter location and bolts up to the 302.
Richard
__________________
As a circle of light increases so does the circumference of darkness around it. - Albert Einstein
alwaysFlOoReD is offline   Reply With Quote
Old 04-24-2012, 07:03 PM   #4
mindlessdrone
Year: 1985
Make: Ford
Model: Bronco II
Default
Thank you very much, very informative. Second question, is the (ZF) about the same fit, clutch and whatnot? Sorry I forgot to say I wanted the granny first. lol
Old 04-25-2012, 11:26 AM   #5
projectnitemare
Year: 1988
Make: Ford
Model: Ranger XLT
Engine: 396W
Class: 4x4 Extreme
Default
The ZF will bolt up. I wouldn't recommend it without a bodylift of you'll be cutting a good bit of your floor.
Matt
__________________
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
© 1999-2012 / 959 Media LLC / All Rights Reserved
[Legal Notices]   [Advertising/Vendors]
Also check out SSP Central for Special Service & Non-Traditional Police & Fire Vehicles
