Home Ford Ranger Forum Builders Guide How To Tech Other Articles Featured Rangers Readers Rangers Classifieds Shirts & Decals
Old 01-20-2012, 06:08 AM   #1
Tractorman86
Vehicle Year: 2004
Vehicle Make: Ford
Vehicle Model: Ranger singlecab shortbed 2wd 2.3
Tractorman86 is on a distinguished road
Default Duratec compatability
So I think the engine in my 04 is blown (possibly rod?) But I found a2010 for 950, will it work as a direct replacement? Thanks
__________________
2004 ranger 2.3duratec 5-speed singlecab shortbed 2wd filter box mod single 2.5"universal cat and 2.5"thrush turbo muffler. Black with black wheels and DARK tint
Tractorman86 is offline   Reply With Quote
Advertisement - Don't want to see the forum ads? Click HERE to find out how to be a Premium Member.
5% Rock Auto Discount Code: 83E98FB3D89C78 Expires: June 26, 2018
Old 01-21-2012, 05:58 PM   #2
Tractorman86
Vehicle Year: 2004
Vehicle Make: Ford
Default
well i'm still not sure what is going on... i pulled the valve cover in hopes i would find a broken cam or some such easy fix but I've still got nothing. the cams and chain look GREAT and all the springs and buckets move the way they should, so i put a compression gauge on it and #1 has 180psi after 3 revolutions #s 2,3&4 have between 210-240psi after 3 revolutions. i found this a little weird because the "knock" i heard sounded like it was from the back of the engine... i guess it is a bottom end problem after all?
__________________
Old 05-16-2012, 01:27 AM   #3
theturbokid83
theturbokid83's Avatar
Vehicle Year: 2008
Vehicle Make: Ford
I use this vehicle for: Every day driving. Mods include cold air intake, 2.5" cat back diablo tuner, 17X8 Mustang GT wheels.
theturbokid83 is on a distinguished road
Default
Did you try a wet compression test on Cyl. one? If there is no real improvement of pressure, do a leak-down test. If it does jump a lot say 50+ psi you have shitty rings. If not, well that sucks. leak down, depends were you hear the air come out. intake=valve exhaust=valve crank case=really bad ring/piston failure. no matter what the heads comming off.
theturbokid83 is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
1999-2018 / 959 Media LLC / All Rights Reserved
