- Oct 17, 2008
- Winona, MN
- Automatic
I had bought replacement switches for my '99, then bought an '01. Anyway, how much is involved in replacing them?
If you mean the cruise toggles on the wheel, it is very simple. dISCONNECT YOUR NEGATIVE BATTERY TERMINAL, Take the airbag out by removing the 2 bolts on the side of the wheel (covered by circular plastic caps). Unplug the air bag and remove. Each toggle is held on by 2 screws, remove them, then unplug the wiring. Install in reverse order.
It isnt as involved as the above post, I believe something there was misunderstood
I took that from the Ford service manual. I have done some like you mentioned but haven't done them on a 2001, so you may be right. Before pulling the steering wheel and the airbag off, he may see the screws above and be able to without removing the wheel.
