Home Ford Ranger Forum Builders Guide How To Tech Other Articles Featured Rangers Readers Rangers Classifieds Shirts & Decals
Go Back   The Ranger Station Forums > Truck Discussions (Not for tech help - Use Help Forums further down) > General Discussions
General Discussions This forum is for general discussions. If you're in need of help, post it below in the appropriate topic forum.
Reply
Thread Tools Display Modes
Old 07-15-2012, 09:43 AM   #1
FORD2011
Junior Member
FORD2011's Avatar
Vehicle Year: 1999...1968
Vehicle Make: Ford
Vehicle Model: ranger...mustang
I use this vehicle for: everyday driving, some off road...drag racing
FORD2011 is on a distinguished road
Default need some help with 4.0 swap into 3.0 ranger
i have just bought a explorer, it is a 99 4.0sohc 5r55e trans 4.10 limited slip. i bought it originally for the rear end, to put into my 99 ranger 3.0 ff. but with 33s my 3.0 is a dog!!! i believe the explorer engine and trans should bolt right up to my bw1354 no problem they are both 99s so the pats system should be the same. can anyone give me some pointers in this swap i want it to go quick and trouble free. wiring differences, fuel pressures, will the flex fuel system in my ranger be a problem (i never run e85). let me know the ins and outs of this thanks
__________________
99 ranger 3.slow
cranked stock keys aal rear 3 inch body
2003 front end custom painted lower and grille
33x12.5 goodyear duratracs
FORD2011 is offline   Reply With Quote
Advertisement - Don't want to see the forum ads? Click HERE to find out how to be a Premium Member.
5% Rock Auto Discount Code: 83E98FB3D89C78 Expires: June 26, 2018
Old 07-15-2012, 06:09 PM   #2
James86
James86's Avatar
Vehicle Year: 1999, 2005
Vehicle Make: Ford, Dodge
Vehicle Model: Ranger XLT, Neon Limited Edition
I use this vehicle for: DD, Things it oughtn't do...
My credo: I'll never let an import in my garage again...
James86 will become famous soon enough
Default
Your 99 has a different sized fuel line and an alcohol sensor in the fuel line. I know because a previous owner jammed the wrong non-FFV filter in the lines on my truck. I'm not sure the fittings will be the same at the engine end of things...
__________________
1999 Ford Ranger XLT, 3.0 FFV.
2005 Dodge Neon Limited Edition.
James86 is offline   Reply With Quote
Old 07-17-2012, 04:55 PM   #3
FORD2011
Junior Member
FORD2011's Avatar
Vehicle Make: Ford
Default
Will the explorer lines fit a ranger whAt about fuel pressures
__________________
99 ranger 3.slow
Old 07-18-2012, 06:47 PM   #4
FORD2011
Junior Member
FORD2011's Avatar
Vehicle Make: Ford
Default
Bump... Can anyone help me out here?
__________________
99 ranger 3.slow
Old 07-18-2012, 07:03 PM   #5
RangerSVT
Oct 09 OTOTM
RangerSVT's Avatar
Vehicle Year: 1996 2002
Vehicle Make: Ford
Vehicle Model: SAS Ranger SC 4x4 V8 Sport Trac
I use this vehicle for: Anger Management
RangerSVT is a splendid one to beholdRangerSVT is a splendid one to beholdRangerSVT is a splendid one to beholdRangerSVT is a splendid one to beholdRangerSVT is a splendid one to beholdRangerSVT is a splendid one to beholdRangerSVT is a splendid one to beholdRangerSVT is a splendid one to behold
Send a message via Yahoo to RangerSVT
Default
Ex lines are shorter than the ranger, and you will also have a pats issue to work out...
SVT
__________________
Ranger V8 Swap Expert
Member of the Turkey Bay Crew
SVT Build Thread (96 V8 Ranger)
ST Build Thread (02 V8 Sport Trac)
V8 swap Club/Info
Tuning with SCT
RangerSVT is offline   Reply With Quote
Old 07-19-2012, 05:15 AM   #6
FORD2011
Junior Member
FORD2011's Avatar
Vehicle Make: Ford
Default
I thought that the 98-01 explorer should have the same pats as my 99 ranger the explorer is a 99 also
__________________
99 ranger 3.slow
Old 07-19-2012, 05:21 AM   #7
FORD2011
Junior Member
FORD2011's Avatar
Vehicle Make: Ford
Default
Ok its not 100% compatable if i want to use my old keys with the explorer pcm i will have to have them reprogramed...ie.keeping the same ignition
__________________
99 ranger 3.slow
Reply
Bookmarks
Tags
3.0 4.0 swap, swap engine
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
1999-2018 / 959 Media LLC / All Rights Reserved
