Home Ford Ranger Forum Builders Guide How To Tech Other Articles Featured Rangers Readers Rangers Classifieds Shirts & Decals
Old 05-02-2008, 09:56 PM   #1
j.apps
j.apps's Avatar
Vehicle Year: 1999
Vehicle Make: Ford 4x4
Vehicle Model: Ranger SuperCab 4x4
I use this vehicle for: my daily driver and mud slinger
j.apps is on a distinguished road
Default 1999 Ford Ranger MisFire
When im driving my 1999 ford ranger down the road it has a horrible mis. Does anyone know where i should start? It have the 4.0 v6.
j.apps is offline   Reply With Quote
Advertisement (Not shown to 'Premium Members')
Old 05-02-2008, 10:53 PM   #2
almostclueless
almostclueless's Avatar
Vehicle Year: 98
Vehicle Make: ford
Vehicle Model: ranger
almostclueless is on a distinguished road
Default
Basics.
1. Fluid levels
2. Change sparkplugs, replacing with autolite double platinums
3. Inspect wires and replace if necessary
4. Ford dealership diagnostic
__________________
1. MORE COWBELL!
2. Chuck Norris can win Connect Four in three moves.
3. What the H___ is an aluminum falcon!?!
4. sham....WOWWWW
almostclueless is offline   Reply With Quote
Old 05-03-2008, 09:24 AM   #3
rangerbert
Junior Member
Vehicle Year: 2002
Vehicle Make: Ford
rangerbert is on a distinguished road
Default
The tune-up should also incude changing fuel filter, and pcv valve. the pcv valve often gets overlooked. If you still have the problems after the tune-up then get the diagnostic tests done.
rangerbert is offline   Reply With Quote
Old 05-05-2008, 02:24 PM   #4
Dajamax
Vehicle Year: 2005
Vehicle Make: Ford
Vehicle Model: Ranger XLT
I use this vehicle for: Everyday driver, occaisonal load hauler.
Dajamax is on a distinguished road
Default
If it's truely a miss-fire, follow the advice previously given.
But another item to check is the Mass Airflow Sensor. If it gets gunked up, your engine performance can change virtually overnight and give you the sensation that it is miss-firing. Usually you can just clean it with electronic spray cleaner or white vineger. It happened to my 4.0L ... the engine shook so bad I thought I had a broken engine mount, or bent drive shaft and/or failed u-joints. After I cleaned the MAF, it ran alot better, but still not perfect. Wound up buying a new MAF, and now the engine runs smooth as silk.
Dajamax is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
1999-2018 / 959 Media LLC / All Rights Reserved
