VIN# decyphering
fmxshark
This is the VIN and what I have found out so far but as you will see I am still missing a few and those are the pieces I need. I am looking to buy new fuel injectors for this truck but I am not with the truck and all I have to go off of is this VIN number. the biggest question right now is that 8th digit.. is this truck direct injection or indirect injection?
2FTHF36K3RCA39490
2 - CANADA
F - FORD
T - TRUCK
H - 8501-9000 LBS.
F36 - ???????(LINE, SERIES, BODY TYPE)
K - ????????(ENGINE TYPE)
3 - IGNORE
R - 1994
C - ONTARIO TRUCK (OAKVILLE, ONTARIO CANADA)
A39490 - FORD DIVISION
edit: 1994 Ford F-350 7.3 turbo diesel
This information is second, maybe third hand, but my googling indicates that VIN K indicates a Non-Powerstroke IDI 7.3L.
Can't you just plug the VIN into Ford Parts and it will tell you what it is?
A 94 is a bit old for that.
https://www.fleet.ford.com/maintenance/vin_tools/
World Manufacturer Identifier - 1st, 2nd, 3rd Positions
VIN Code: 2FT
Assembly Country: CANADA
Make: Ford
Body Style: Pickup
Restraint System Type (Passenger Cars) or Brake Type and GVWR Class (Trucks and Vans) - 4th Position
VIN Code: H
Brake System: STANDARD
GVWR Class:
Restraint: ACTIVE (MANUAL) BELTS
GVWR Range: 6,001 - 10,000 Pounds
Line,Series Body Type - 5th, 6th, 7th Positions
VIN Code: F36
Vehicle Line: F-350
Vehicle Type: Truck
Engine Type - 8th Position
VIN Code: K
Engine: 7.3 L
Cylinders: 8
Fuel: Diesel
Engine Manufacturer: INTERNATIONAL
Model Year - 10th Position
VIN Code: R
Model Year: 1994
Assembly Plant - 11th Position
VIN Code: C
Assembly Plant: ONTARIO TRUCKS, ONTARIO
Production Sequence Number - 12th - 17th
VIN Code: A39490
Prod Sequence Number A39490
