- May 19, 2013
- Manual
Have a 96 3.0 4x4 motor blew. Just swapped in another motor from a 94, so had to add the newer timing cover for crank sensor and had to drop in the cam sensor. Fired up ran not bad but constantly back fires crawled under to check for leaks and saw the cats glowing any ideas?
im wondering did i not get it at perfect TDC when i dropped in the cam syncro? the carnk is the 94 and the crance pully is the 96(with the sensor ring
