Hello,
I recently needed to change my wheel bearings and seals on my 1997 Dana 35 TTB.
In the Tech section I couldn't find info on the exact sizes of the o-rings needed for the Wheel to Rotor area or the o-ring in the Warn manual locking hub. I found the sizes in the forum section.
Is there a place in the Tech section you could put these measurements and pictures for others to find?
Wheel to Rotor O-ring = 3-1/2 Inside Diameter X 3-11/16 Outside Diameter
Warn manual locking hub O-ring = 5/8 Inside Diameter X 7/8 Outside Diameter
Bought from a hydraulics repair shop:
80 cents CDN each for Wheel to Rotor O-ring
15 cents CDN each for Warn manual locking hub O-ring
These O-rings are rated for 250 C / 482 F and they're working great for me. Just replace if you see deterioration.
Thank you very much for this great forum and awesome tech section!!
Billy
Billy
