Attention ALL 2.3L Turbo owners --->
Jim Oaks
Just some guy with a website
Founder / Site Owner
Administrator
💻 TRS Socials
TRS 25th Anniversary
Nocona
TX - USA
Other
2005 Jaguar XJ8
Vehicle
Drive
2.3 EcoBoost
3.5-inches
Our 2.3 turbo discussions are getting scattererd. Please place all your turbo discussions in this forum. If you have a turbo thread going in the 4-cylinder forum, please have it moved here.
Thanks.
Could there be a consolidated thread for those looking for info for doing this swap? The format would be as follows:
1) Engine (year/model/options) going into ranger (year ranges, models, etc.)
a) versions of engines (pros of each)
b) versions of ecus (pros of each)
c) year ranges of ranger pros and cons (difficulties, ecu and wiring differences, etc..)
2) Tuning
a) What is needed to run a stock turbo ecu in each year range ranger
b) converting dual plug harness to work with single plug ecu (or can the stock harness be kept and just delete one coil pack?)
c) how to tune the stock ecus (versions and benefits) from start to finish with each tuning option.
d) where to get base maps, how to make changes, etc... (yeah liability etc... each person is responsible for their car yada yada)
3) supporting mods
a) Transmission (is it strong enough, upgrades, clutches, fluid)
b) Driveline (what rear ends are good, ratios, etc...)
c) OEM boost control, aftermarket boost control, MBC, none (benefits of each)
d) Radiators/Cooling mods
Anything else I missed.
Compiling this information would be very beneficial. Linked below is a vwvortex thread that is a great example.
https://forums.vwvortex.com/showthread.php?6137862-A1-Vr6-FAQ
https://forums.vwvortex.com/showthread.php?1535079-lets-get-a-ABA-16v-Parts-List-FAQ-Thread-going
