Home Ford Ranger Forum Builders Guide How To Tech Other Articles Featured Rangers Readers Rangers Classifieds Shirts & Decals
Old 09-03-2009, 05:19 PM   #1
alwaysFlOoReD
I want a belly rub...
alwaysFlOoReD's Avatar
Vehicle Year: '91, '94, '77
Vehicle Make: ford
Vehicle Model: ranger, ranger, f-250
I use this vehicle for: 4x4 race, 4x4, towing
alwaysFlOoReD has much to be proud ofalwaysFlOoReD has much to be proud ofalwaysFlOoReD has much to be proud ofalwaysFlOoReD has much to be proud ofalwaysFlOoReD has much to be proud ofalwaysFlOoReD has much to be proud ofalwaysFlOoReD has much to be proud ofalwaysFlOoReD has much to be proud ofalwaysFlOoReD has much to be proud of
Default hood stuck shut fix
My wife's girlfriend's '95 f-150 hood was stuck closed. I reached through the grill with a 1/4" drive ten mm socket and loosened the two bolts holding the latch to the radiator support. Then used a stubby 10 mm wrench, then my fingers to finally remove the bolts. The hood then popped open enough to remove the latch from the hood. Replaced latch to rad support and centered to the hole in the hood. Problem fixed!!!
alwaysFlOoReD is offline   Reply With Quote
Advertisement - Don't want to see the forum ads? Click HERE to find out how to be a Premium Member.
5% Rock Auto Discount Code: 83E98FB3D89C78 Expires: June 26, 2018
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
My dome light will not shut off! (fix inside) Captain Ledd Interior 22 12-20-2012 03:11 PM
01-03 Edge/4x4 Hood? lindsay_elaine Exterior 14 06-07-2009 08:15 PM
Ranger Hood Hinge Swap to 1995 to 2001 Explorer Hood Hinge with Shock Mike Tech Exterior 13 06-02-2009 02:16 PM
You know your stuck when.... The Jester Race The Tailgate 26 01-03-2009 11:22 PM
Mustang Scoop into Explorer/Ranger Hood Spdrcer34 Exterior 6 12-22-2008 12:01 PM
1999-2018 / 959 Media LLC / All Rights Reserved
