Home Ford Ranger Forum Builders Guide How To Tech Other Articles Featured Rangers Readers Rangers Classifieds Shirts & Decals
Old 01-20-2008, 06:17 PM   #11
fordman8991
Junior Member
fordman8991's Avatar
Vehicle Year: 1989
Vehicle Make: ford
Vehicle Model: ranger
fordman8991 is on a distinguished road
Default
Quote:
Originally Posted by AllanD View Post
The 4.0 flywheel sits much closer to the block because it's thicker
and yes the dust shield is different as well to clear it.
AD
alright. well monday i shall get a dust cover and try it again.
what about wiring. what has to be changed. i picked up a manual ecu for it and i have the clutch pedal sensor hooked up and it works.(tested it) i was messin around since i couldn't install just seeing if i could get power to the ignition starter wire. and when i pushed in the clutch and turned the key to the start position i get no power to the ignition wire? what do i need to do to make this work?
fordman8991 is offline   Reply With Quote
Advertisement - Don't want to see the forum ads? Click HERE to find out how to be a Premium Member.
5% Rock Auto Discount Code: 83E98FB3D89C78 Expires: June 26, 2018
Old 01-23-2008, 02:19 AM   #12
91exploreron37
91exploreron37's Avatar
Vehicle Year: 1991
Vehicle Make: Ford
Vehicle Model: Explorer
91exploreron37 is on a distinguished road
Default
Arent the spacer plates different between the 4.0 and 2.9 so since you have a 4.0 dont you need the spacer plate from a 4.0?
To get it to start you have to splice two wires together from the nuetral saftey switch from the auto trans. I think it's like red w/blue stripe and red w/white stripe but im not positve.
__________________
91 Eddie Bauer
Rebuilt 4.0, head work, 422 cam, headers, dual valve springs, manual tranny and t-case swap, Warn manual hubs, 3in body, 4in susp, 1in shackle and spacer, 35in BFG M/Ts on 15x8 black rockcrawlers, no cats, 3in CherryBomb PRO/dual turndowns, 5% tint, 5.13s, Kennesaw winch bumper, Centerforce DF Clutch
Quote:
Originally Posted by davey2451 View Post
im goin for 70% looks and 30% funcktion
91exploreron37 is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
1999-2018 / 959 Media LLC / All Rights Reserved
