Home Ford Ranger Forum Builders Guide How To Tech Other Articles Featured Rangers Readers Rangers Classifieds Shirts & Decals
Old 07-23-2010, 10:56 PM   #1
dedricreed
Vehicle Year: 1994
Vehicle Make: ford
Vehicle Model: ranger
dedricreed is on a distinguished road
Default How to check coil packs on 2.3 l
Anyone??? I've used the search and I see to check primary and secondary but I've found different reports of what they should read. I'm also still unclear as to how I test it and the ohm range to look for when testing it.
dedricreed is offline   Reply With Quote
Advertisement - Don't want to see the forum ads? Click HERE to find out how to be a Premium Member.
5% Rock Auto Discount Code: 83E98FB3D89C78 Expires: June 26, 2018
Old 07-24-2010, 06:42 AM   #2
modelageek
modelageek's Avatar
Vehicle Year: 2004
Vehicle Make: Ford
Vehicle Model: Ext Cab, 4WD, Auto, 4WABS, AC, 140k/90k.
modelageek will become famous soon enough
Default
Quote:
1) you should get a haynes maual...page 5-4. primary less than 5 ohms, probe the center terminal and either side of the other 2 on the primary terminal. secondary 13k-15k ohms, probe thewire sockets in pairs 1/4, 2/3
2) if you want to test the coils fine but if you are having an issue with the truck post what the problem is and maybe we can help.
3) you also can swap the coils and if the truck runs differently then you know it is a coil.
__________________
2004 Ext Cab, 4WD, 4.0, Auto, 153k(engine is out of a 2009 Ranger with 95k) Mileage readings as of 5/14/2017
2004 Ford Ranger Edge, Ext Cab, 2WD, 3.0, 5 speed, 116,000, AC. (SOLD)
1999 Ford Ranger, Reg Cab, 2.5, 5 speed, 2WD, no AC, 150k (SOLD)
modelageek is offline   Reply With Quote
Old 07-25-2010, 09:16 PM   #3
pinturbo75
pinturbo75's Avatar
Vehicle Year: 1992
Vehicle Make: ranger
Vehicle Model: xlt
I use this vehicle for: work truck
pinturbo75 is on a distinguished road
Default
whats wrong with just puttiing a timing gun on one plug wire of each of them to see if they are firing? seems a simple way to check it to me...
__________________
92 ranger 2.3 5sp... soon to be turbo
75 pinto turbo
pinturbo75 is offline   Reply With Quote
Old 09-15-2012, 04:56 AM   #4
1994RANGER1994
Vehicle Year: 1994
Vehicle Make: FORD
Vehicle Model: RANGER
1994RANGER1994 is on a distinguished road
Default
Quote:
that would tell you if it is sparking, but doesn't automaticlly mean coil could be wiring or ign module.
1994RANGER1994 is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
1999-2018 / 959 Media LLC / All Rights Reserved
