- Oct 24, 2012
- Reaction score
- 551
- Location
- Middle Tennessee
- Make / Model
- Ford
- Engine Type
- 4.0 V6
- Engine Size
- 4.0
- Manual
- 2WD / 4WD
- 4WD
- Total Lift
- 1.5" Front + 4" Rear
- Tire Size
- 245-70-R16
You can unbolt the fan blades but can't remove them with the clutch still on the truck. Although if your blades are being replaced, you might be able to do something with a grinder..
It's tight but I usually manage to work everything between 2 blades...
