cruise control swap
parisot
4
Well to start this off, I read in the tech library the artical about puting after market cruise control in a ranger and it stated that taking the stock cruise control out of a doner truck is a PITA. Well I would say calling it a PITA is a bit of an understatment....
here is what i got
doner 93 ranger 4x4 auto 4.0 with cruise control
swaping to 91 ranger 4x4 manual 4.0 no cruise control yet
So far i have the all of the wiring traced and pulled out of the wiring harness. I pulled the wiring that runs to the stearing wheel, then the two connectors that run to the glove box and connects to the cruise control computer of some type. from there one of the connectors runs to the cruise control module mounted on the drivers side fender. The other connector has a wire that runs to a ground, a wire that runs to the fuse box a blue green wire, and three wires that run through the big connector in the fire wall. A pink with orange stripe, a solid green wire, and a grey with black stripe. does anyone know or does anyone have a wiring diagram that will tell me where these wire run too? I really dont want to rip all of the wiring harnes out of the engine bay to find out...
All help is appreciated,
Thanks
parisot
4
reading back through the cruise control sticky, i see that the vss is usually a grey black wire. so that solves one wire. any ideas on the others?
Earl43P
38
Farmington, Pa
Ford F250 4WD
parisot
4
http://www.therangerstation.com/tech_library/EDiagrams/files/Diagram_Cruisecontrol_1of2.JPG
http://www.therangerstation.com/tech_library/EDiagrams/files/Diagram_Cruisecontrol_2of2.JPG
These do you any good? Send me a PM with your e-mail address, I'll send you the 93 schematic for Cruise and a bunch of other stuff (all 93).
yes that helps me. I didnt realize that there were wiring diagrams in the tech library.. PM sent too..
So by looking at the diagram,
pink orange is just another ground
gray black is the vss
light green is a constant power that turns off cruise control when interupted?
I dont see a blue/green wire that is fused on those diagrams though. any ideas on that?
Also, does anyone know where i could tie into the vss wire on my 91 ranger?
parisot
4
ok, i found out that the blue/green wire is switched power(switched with the key in acc. or run position) that runs through a 10 amp fuse.
I guess that leaves me with only one question. does anyone know where i can tie into the vss wire (grey black) on my 91 ranger?
parisot
4
i think i have solved all of my questions except one. Can anyone tell me if i can just tie the pink/orange wire comming out of the VSS Amplifier to ground since that is how it is being shown on the wiring diagram?
  • ryan
    Forum Administrator
