guitardude2007
- Oct 4, 2014
- Reaction score
- 0
- Location
- Yarmouth, NS, Canada
- Make / Model
- Ford
- Engine Size
- 4.0
- Manual
Sorry if this information is already somewhere I have searched for a fix and everyone with this problem there 4wd doesn't work at all or so it seemed like. My 4wd works fine shifts from 2wd to 4h and 4l fine and smoothly and lights work as expected except for when driving the lights flash every couple mins. I believe they are flashing 6 times but cant say for sure as I try to watch the road as well. (seems like when I go over 50 kilometers per hour they start)
Fuses are all good, switch must be good as well as motor since it shifts ok. I haven't looked into this a whole lot as far as tests go I just wanted to see if someone else had this issue with the 4wd working fine. It does seem tho that after driving for awhile and trying to select 4wd it doesn't work unless I turn the key off and then on. 1997 ranger with 4.0l and 5 speed, manual hubs. This being my first ranger I am unfamiliar with some things and saw on here some tests at the module but said it was behind the jump seat I have a regular cab so not sure where that would be I know there is some modules related to 4wd behind the radio like the GEM is that the module to test? Any help would be much appreciated thanks in advance.
