Drive shaft leak?
Mbrockman5
2.9L
I have an 88 ranger 4x4, and noticed a puddle under my truck below my rear diff and drive shaft area. Can anyone tell me what's going on? Or any advice on how to fix it?
Sent from my iPhone using Tapatalk - now Free
UrbanRedneckKid
Solid Axle Swap
17
Cass Co, Missouri
4.0L
Did your pinion nut back off?
Assuming the leak is in front of the yoke, if it's behind the yoke then a new pinion seal is in order.
Pull the driveshaft, remove the pinion nut and washer.
Brake clean the $#!+ out of it, make sure it's clean and dry, smear some etc down in there around the splines.
Reinstall the washer and nut, with red loctite, tighten as per manufacture's specification. (i won't say how, too many people get it wrong)
Reinstall the driveshaft.
Don't forget to top off the fluid, to the bottom of the hole, parked on a level surface.
Sent from my HTCONE using Tapatalk 2
adsm08
Senior Master Grease Monkey
Ford Technician
3,613
Dillsburg PA
Engine Type
4.0
2WD / 4WD
31X10.50X15
Yeah, kinda looks like the rear is leaking past the pinion nut.
That's a new one on me though. Usually pinion leaks run down the diff.
UrbanRedneckKid
Solid Axle Swap
17
Cass Co, Missouri
4.0L
You haven't seen that yet...?! I fix probably 1-2 a month.
Oh but your a dealer tech, you probably don't see to many high mileage trucks.
adsm08
Ford Technician
3,613
Dillsburg PA
Engine Type
4.0
2WD / 4WD
31X10.50X15
I see leaking pinion seals all the time. Most vehicles that I work on fall into one of two categories, less than 30K or more than 75. Also, look at what I drive. I am my shop's expert on "high mileage rusty junk", as I put it.
What I meant is that I has never seen the leak in that particular pattern before, where the U-joint flange is soaked but it doesn't look like there is a drop on the diff housing.
jhammel85
Guest
Ditto....That looks pretty bad. If I were you, I would start taking it apart and having a look. If you get the drive shaft off and find that the nut is loose, something odd is going on.
I would replace that seal and see if it helps. I'd look into looking for a sleeve for the pinion flange as well. I bet it's leaking due to some bad scoring and the lipseal is gone too.
Make sure to follow the instructions, especially when setting the pinion nut torque.
http://www.therangerstation.com/forums/showthread.php?t=102444
Mbrockman5
2.9L
Ok. Do you think I'm looking at a good chunk of change for the repair? I'm sure I can do the labor myself, but current "fundage" is pretty low to pay for someone else to fix it.
UrbanRedneckKid
Solid Axle Swap
17
Cass Co, Missouri
4.0L
Should be an hour labor and shop supplies, if the pinion seal and bearings are ok.
jhammel85
Guest
Agreed. Honestly though, If you have a standard tool set and a cheap puller, it'll
be worth doing it yourself. The parts are so cheap....The only "difficult" part is setting the load on the pinion bearing. Even that isnt' that big of a deal.
Sasquatch_Ryda
Ford Technician
OTOTM Winner
Solid Axle Swap
Forum Staff - Retired
TRS Banner 2012-2015
108
Terrace, BC, Canada
Engine Type
4.0L
2WD / 4WD
Solid Axle Swap 4x4
40s
Seen that where it is actually leaking up past the splines inside the flange....not the seal. Usually due to worn splines. You can get away with removing the flange (replace the seal anyways since you are in there) and clean up everything and reinstall the flange with some RTV on the pinion splines.
Mbrockman5
2.9L
Ok. I need to invest in a repair manual. But I'm sure I can tackle it at home. This issue just pooped out of no where(popped, pooped, whatever, haha) the last "major" thing I did with the truck was hauling an upright freezer home, and my heater core blew on that same trip. Of course this has to happen right before hunting season starts......
Mbrockman5
2.9L
Here are a couple closer shots if that helps anyone get a better idea....
UrbanRedneckKid
Solid Axle Swap
17
Cass Co, Missouri
4.0L
Yup, pinion nut is leaking.
Mbrockman5
2.9L
Ok..... So I failed to mention that my truck is backed up in my driveway at an angle. I was reading the reply' and noticed some comments about where it's leaking. And after some research and looking at my pictures, I see that the whole flange is black. Which leads me to believe that the leak is coming from the pinion seal. Can anyone back me on that?
UrbanRedneckKid
Solid Axle Swap
17
Cass Co, Missouri
4.0L
Why haven't you pulled the driveshaft and actually looked at both sides of the pinion flange yet?
Internet diagnosis will only get you so far...
Staff online
Today's birthdays
Shran
April Truck of The Month
