94 Ford Ranger 2.3 Cranks but no start
ChillyWilly94
As tile said I got a 94 Ranger
It will turn over fine but won't start
>Timing is correct
>spark plugs are new Bosch
>New plug wires
>New coil packs
>New CPS
>MAF is original but works fine
>New fuel Pump and filter
>New fuel pump and ecm relays
>Tps is within specs
>New ICV
>Rebuilt engine and drove about 1K
Here are the codes i got too
543
172
118
Really love my truck but I need to get it running , Any help is greatly appreciated
turbo91xlt
RBV's on Boost
63
Goshen, NY
1992
can you hear the fuel pump coming on?
ChillyWilly94
Yes it comes on when you turn the key
ChillyWilly94
Alright so I figured out most of the problem turns out I had a lot of water and my gas from when I removed my bed for painting and all those days exposed to the rains in Florida I managed to drain the whole tank put fresh gas and a few bottles and heet and I cleaned the MAF . I smoked my intake with a fog machine and realized that I had a small vacuum leak at the carbon canister next to the battery so I replaced that hose and now the engine runs significantly better and doesn't stumble when I turn on the AC, the RPMs are still lower with the AC but I guess that's the extra load . Still surging when coming to a stop but I have yet to find that out.
Staff online
Shran
April Truck of The Month
