- Aug 26, 2008
- Reaction score
- 13
- Make / Model
- 1994 Ford Bronc
- Engine Size
- 5.8v8
- Automatic
- My credo
- Failing is easy. Everyone can do it.
Okay, 1995 Explorer yadda yadda yadda.... Did a short post about a rear hatch to replace our rotted out one.
Did some digging around online:
This just got interesting, and probably will require some custom fab work.
Looks like this gate, which came off a "1996" Explorer according to the ident sticker the yard has on the sides of the body. (no registration stickers, they get scrapped off when it's processed. So much for a quick glance)
This rear gate came off a 1998 or newer Explorer. This one has the license plate mount and lighting in the hatch itself. So that explains the wiring difference for the wiper motor. They diverted some of the wires to light the plate up, and went with a "motor park sense" system on the GEM module and not the 3 wire position system they used to have. That itself will be a challenge to figure out, but not impossible.
I will be heading back to the yard tomorrow morning. The newer gate does bolt up and is secure (locks work, seals against the back of the truck...etc.. Actually looks pretty good until one glances at the tail lights)
My concern is the tail lights and their shape. The curve looks to match the rear hatch and it has that depression of about 1 1/2 inch from the metal of the hatch. The old hatch was more boxy and the new hatch has that gentle curve to it. So my current tail lights are not curved to match, but are 'flat faced'.
We are planning on snagging the rear trim piece for the hatch, as mine won't line up or mount. I'm sure to get hosed on that chuck of plastic for the $$. I would also like to snag the tail lights. But need to know if anyone has done this before, and if the tail light mount to the body would be plug and play--of if a lot of modify work would need to be done.
The old gate is not going back onto the Explorer. The entire bottom of the hatch was/is rotted out with some good size rust holes in it. Granted they are not visible when the hatch is shut. But lift it up? And the bottom panel is roached. Each time I closed it? It's like a shower of rust falling onto the rear bumper.
Suggestions are welcome. I can live with the indented tail lights if I have to. Just want to try and make this look as factory as possible. There's no more serviceable hatches in the yard(s) that are in good shape, They even had one that was done in about 4" of colored duct tape due to all the rot.
S-
S-
