Noisy limited slip?
Truckedup
Marion NY
4.0
I have owned for about three months an 09 Ranger Sport 4.0 5 speed 4x4 with the stock limited slip rear axle, R6 code...94,000 miles and it seems to have not been abused..
The posi seems to function normally but at slow speeds making sharp right or left turns there a slight humming noise or low "squealing" noise from the rear axle. It's noticeable when coasting or at neutral throttle, step on the gas a bit and the noise seems to disappear..Other than low speed sharp turns the rear axle is quiet...
I have both a Chevy and Jeep with limited slips and they don't make this noise but like the Ranger they do chatter a bit when turning on loose surfaces...
No know history so maybe I should just change the rear axle oil....:icon_confused:
Denisefwd93
74
South East PA
Engine Type
4.0
2WD / 4WD
Looks like your post was missed by the many responders on the site! anyhow welcome to the site!
I feel your pain, my truck is essentially doing the same thing it's rather unsettling.
Craig0320
225
Mississppi
Engine Type
V8
5.0
2WD / 4WD
Break it right the first time. Fix it better the next time.
I have the 8.8 limited slip in my 98 ranger. I changed the gear oil and did not add a friction modifier. Thus when everything was hot I had a vibration/grumble on first take off or sharp turns. Pull the pan and inspect the gears. If there is no scoring and not to much slop in the ring and pinon then you might be able to get by with just a fluid change. Just make sure the oil you put in has friction modifier or just add some. The modifier keeps the clutches from grabbing in our l/s rear end. I used mobil synthetic with friction modifier and it has been super quiet ever since.
adsm08
Senior Master Grease Monkey
Ford Technician
3,613
Dillsburg PA
Engine Type
4.0
2WD / 4WD
31X10.50X15
Change your rear end clutches. They are rated for approx 100,000 mile service life. If you have any issues with chatter, noise, grabbing, or lack of traction, etc above 90,000 miles, just change the clutches.
Truckedup
Marion NY
4.0
I changed the oil to Mobil 1 75-140 yesterday before checking back to this thread...The noise is gone,the chatter is gone, the limited slip still seems to work ok....
During the summer I'll check it. I've worked on Chevy posi's, I assume the Ford is similar, pull the axles, remove the differential for clutch replacement ?
Craig0320
225
Mississppi
Engine Type
V8
5.0
2WD / 4WD
Good deal. The fluid change solved mine as well.
Denisefwd93
74
South East PA
Engine Type
4.0
2WD / 4WD
Good on ya! I may try the same on my truck, bide some time to work the truck we got last night
Denisefwd93
74
South East PA
Engine Type
4.0
2WD / 4WD
What did y'all use? Yukon, Lucas, or purple?
Craig0320
225
Mississppi
Engine Type
V8
5.0
2WD / 4WD
I use mobil one gear oil.
Denisefwd93
74
South East PA
Engine Type
4.0
2WD / 4WD
I got the same.. store person wants model make for off the shelf oils even LOL
adsm08
Ford Technician
3,613
Dillsburg PA
Engine Type
4.0
2WD / 4WD
31X10.50X15
You used to do HVAC, right?
Someone walks into your store and asked for a piece of stove pipe do you ask for some info about what they are doing with it, or do you just hand them any random thing? What if they need 8-in double wall to go through a wall and you hand them 6-in single and they smoke out the house right before it burns down?
Same with oil. You can't just say "I need oil for my car" and expect to get the right stuff. Hondas and Toyotas like 0W-20. Most diesels take 15W-40. Neither of those are the 5W-30 the book for your truck calls for.
Will
Forum Staff Member
514
Gnaw Bone, Indiana
Toyota
4.0
It's not that sophisticated. If a manufacturer specifies something extremely weird they are either trying to crutch a design flaw or they are the only one making the specific product and trying to screw you. Honda is famous for never telling you what other compatible brands work. The low viscosity stuff is because they could only meet EPA mpg with thin oil. It's not at all like specifying the wrong stove pipe in a house. You could put straight 30 dino into about any mechanical object and it would be fine for years. That includes using it for 2-strokes and mixing it into JP-8 to lube diesel engine injection pumps.
All the specifications are polish. Main thing is to not run without oil.
Truckedup
Marion NY
4.0
That's a very broad statement and there is a pile of experience stating otherwise...
Staff online
Today's birthdays
Shran
April Truck of The Month
