zachis4wheeling
- Aug 20, 2007
- Reaction score
- 0
- Location
- Port Huron, Michigan
- Make / Model
- drof
- Automatic
UPDATE 2/13/14! 2.9 GURUs....HELP! rough idle, random stalling then dead for good....
UPDATE- 2/13/14
Trucks an 87 reg cab, long bed, 4x4 2.9 5 speed
I bought a new in-tank low pressure fuel pump, a new high pressure external fuel pump along with a new fuel filter and installed them all today. Well, everything but the fuel filter, but thats another story.
Before I go much further, here's what led up to this. 3 months ago, in November, I bought a new set of tires for this thing and was loving the hell out of driving it. It had sat for like a year before that, waiting on a clutch to be done on it. Twice, while driving, it would for no reason at all stall out completely like it was being starved of fuel. Usually if I let it sit for about an hour, it would start up then, after about 5-10 rotations of the key to prime the fuel system. It wasnt a huge deal to me, as I only drove the truck here and there, but it wasn't my DD.
Well a month ago, in the Harbor East section of downtown Baltimore (high falOOting snob area) while driving with my buddy, the truck dies right in the middle of the road. I loved it cuz it so easily pissed off these idiots down there. I'd been driving it for hours that day before this happened. And this time, it wouldnt fire at all. Buddy went and got a can of ether and when we sprayed that into the intake, it would run fine, but nothing else. Couldnt hear the pumps prime or anything. Had it towed back to my house and it sat until this past weekend when I got some time to pull the bed and do work.
I installed both the low and high pressure pumps but the filter they gave me doesn't match the one thats on the truck, so no bueno yet on the new filter.
Went to start it and all it does is crank. No fuel pump whine, no buzzing nothing. I can hear the relay engage, but no fuel pump buzzing or anything. I double checked all the wires running to the pumps and everything is hooked up where it is supposed to be.
Here is what I have done so far:
-I checked for spark (we are good for spark)
-I looked at the fuse panel under the steering wheel but didnt see anything for the fuel pump written on the diagram.
-I sprayed ether in the intake again with my roommate cranking and it fires up and runs on ether...
I don't want to run around and install a bunch of non-needed expensive sensors, etc that don't need to be done. I just want to track down the problem and fix it. I don't want to diagnose this problem by financial ruin (installing un-needed expensive parts). HOWEVER.....if there is a cheap sensor or something I can do that sounds like it may be the problem, I'm all ears. Never hurts to do preventative cheap part replacement every now and then....
I know I should do the filter at this time as well, and I fully plan on it, but I also know without a doubt, that this problem right now is electrical and not a clogged filter.
I have read about jumping wires from some relay to send power to the pumps 24/7.....I have no clue what this entails. Anyone know about this?
I'm also rather clueless when it comes to the electronics on this thing, or any vehicle for that matter, so any pointers or (more than likely fixes) are much appreciated, along with an idiots walk thru guide....that would be awesome.
Thanks a ton in advance.
UPDATE- 2/13/14
