martianable
- Nov 17, 2011
- Reaction score
- 0
- Make / Model
- Ford
- Engine Size
- 3.0
- Automatic
Hello All,
I have a mystery that perhaps could be solved here and also answer anyone else's questions to boot. I cannot find the answer or part anywhere - been searching for days now - Yikes !
Symptoms:
Brake fluid leaking from beneath o-ring on 'Mystery Valve' - when the brake pedal is pushed in you can actually see the fluid leaking out from under the o-ring in the pictures - I find this assembly to be quite strange as this screw in valve doesn't seem to come apart where the o-ring is seated but there is a small hole in the groove underneath - is that a pressure relief hole under the o-ring ?
Rear port of Master Brake Cylinder - Screwed into MBC - see photos.
I cannot find this part anywhere but stamped into the metal is '223962'
Please help me identify where to get this part so I can move on with my life thanks !
Marty
Symptoms:
Marty
