raggedyann
- Feb 20, 2013
- Reaction score
- 1
- Make / Model
- ford
- Automatic
1987 Ranger losing prime fuel pump
stx 2.9 I must cycle key on/off several times before it will start. like its losing prime. it does this hot or cold.
would the fault be a bad pump check valve ? it has the frame mounted pump and the in-tank pump.
no fuel at FPR vacuum line.
any tests to tell which pump is faulty ??
