whitebroncoii87
- May 23, 2015
- Reaction score
- 1
- Location
- 11354
- Make / Model
bronco ii
rang
I have 87 broncoii with 2.9l. Should I adjust lash by tighten down adjuster nut based on lash between rocker arm and pushrod or rocker arm and valve stem? If valve stem should I put a feeler gauge (what size) in between or just visually confirm they are barely touching then 1 1/2 turn thereafter (whereas pushrod is 1/2 after they have touched).. Thank you
