travis
- Jan 12, 2011
- Reaction score
- 0
- Make / Model
- ford
- Engine Size
- 302
My high beams seem fine but my low beams are very dim. Also my high beam indicator is always on when headlights are on. I checked and cleaned multi switch or turn signal hi low beam switch witch ever one you want call it checked all connections and grounds. All seem good. Checked volts on light plug and there's 12 volts on both high and low wires when high beams are on. Switch to low beams and drops to 3.5 on low beam. Should it b 12 volts on low beam also? Like I said I took multi switch apart and cleaned all contacts and put back together. Also did same with light switch itself. Any info would be great. Not the best at wiring stuff. Lol
