96 explorer 4.0 into a 91 4.0 ranger
Ranger Philly
Rapid City, So. Dakota
4.0l V6
Hey Guys...quick question! I have a 91 Ranger SXT with the 4.0 in it currently. The stock motor has typical lifter noise leaks and what not. (190k on it!!!) I found a steal on a 4.0 out of a 96 explorer here local. talking to the seller he doesn't seem to know a lot about what he has so I figured that I would hit y'all up and see if it would work for me. He does have the harnesses but not the computer. It should fit just fine but will the wiring be plug and play? Any issues with mounting?
Any advise would be greatly appreciated!! Thanks for looking!!
alwaysFlOoReD
5,086
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
I'm putting a 91 into a 94. I'm swapping everything not the same between motors. Only thing so far is the belt tensioner but I haven't finished. Pretty easy to spot differences when both are sitting side by side.
Sent from my XT1032 using Tapatalk
Ranger Philly
4.0l V6
Thanks for the info...so I can assume that if everything is different the sensors are going to talk to the computer I currently have in the pickup the way they are supposed to....damn!
Will the stock electronics...harness, sensors, accessories, etc...swap over to the newer motor clean? Or am I going to have to mad scientist the harness to make everything work??
alwaysFlOoReD
5,086
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
What I'm doing is making sure the new motor has exactly the same sensors as the old motor and using the old motors ecm and wiring.
Ranger Philly
4.0l V6
Problem solved...found this little jem for sale online today. Picked it up for $500. Oh doctor prepare the operating table for donor surgery!
