need info
- May 20, 2016
- Reaction score
- 15
- Make / Model
- ford
- Manual
hello, I have a 4 cylinder 5 speed manual ranger 2.5 l engine. I bled the slave cylinder after the hydraulic line was disconnected. After I bled the slave cylinder I have a good solid peddle. Now at idle or starting out in 1st gear as usual. I have clutch chatter going on. As if the clutch is engaging without enough gas peddle. Does this mean that I have air in the system still? Thanks.
