Dave-X
- Jan 22, 2009
- Reaction score
- 0
I took my ranger with me on some errands today and got stranded at the grocery store when it wouldn't start. There was a strong engine turn over but it would not start after several attempts. I let it sit for half an hour and it still failed to start.
However, I went back 5 hours later and it fired up so I got it home without issues. It also started again after I parked it.
I had the exact same problem in 2014 and had a "Cooling Temp Sensor" replaced. According to the mechanic it was reading invalid temperatures and causing the fuel mixture to be too rich.
Before turning it off I read all the ODBII data (posted below). I'm not sure if any of it helps but this was taken at idle. Does anyone have any thoughts?. I can answer any questions and post pictures if needed.
Thanks guys!
MAF/ 4.4 g/s
STFT1: -3% to 3%
STFT2: -7% to 3%
BOOST: -12.3 PSI
F/T 1x1: -2.3 to 3%
F/T 2x1: -4 to 2.3%
LPK(avg) 6.5L / 100 km
LTF1: 9.4%
LTF2: 9.4%
F/T 1 Long Term 10%
F/T 2 Long Term 9.38%
Thanks guys!
MAF/ 4.4 g/s
STFT1: -3% to 3%
STFT2: -7% to 3%
BOOST: -12.3 PSI
F/T 1x1: -2.3 to 3%
F/T 2x1: -4 to 2.3%
LTF1: 9.4%
LTF2: 9.4%
F/T 1 Long Term 10%
