1994 Mazda B4000 no turn signals
dreymeek
2
Hillsboro, OR
Mazda
4.0 v6
The Cobbler's children go barefoot.
This truck has sat for 3 years. It got moisture in the cab and molded up pretty well. When I first tested the lights, I had brakes, headlights, tail lights, and front E flashers. When you activate the turn signal, the flasher would click once but never flash a light. I replaced the switch ass'y and that brought back the rear flashers, but no turn signals. I tested for power at the turn signal plug and had 6.8v at the red wire. I checked at the fuse and I have 12v on 1 side and 10.5v on the other side which I thought was weird. I also removed the flasher and put a jumper wire across the 2 terminals to see if the flasher was bad, but still no lights.
Anybody have ideas?
dreymeek
2
Hillsboro, OR
Mazda
4.0 v6
I ended up replacing the flasher for the turn signals, all is good now. Next is tot figure out the electronic 4x4 not working.
Staff online
Shran
April Truck of The Month
