fuel system question
memorex402
North Carolina
I have the 2.9 engine. While changing a fuel pump and fuel line to the pump a fitting got broke. The fittin is on a black box that sits right beside the tcase. I beleive this is an accumulator. The feed and return both hook up to this. My question is... Is this an accumulator? Where can I order it? And could I possibly by-pass it with no problems.
dave2575
Bay Area, Nor Cal
mostly 88
"BIGGER HAMMER!"
I had the same thing happen to me. the accumulator is mounted under the cross member and beside the t-case(it has a bowl threaded on the bottom of a square shaped box and 4 plastic fittings coming off it) I by-passed mine with a couple of fittings and have had no problems with the inline pump. I tried to find another one at j-yards and even the dealer with no luck. good luck.
memorex402
North Carolina
I appreciate the response. I guess I will bypass it later this week once I have time. You have no problems with it once the motor gets warmed up? I saw a post somewhere on the net claiming that it would cause issues when the motor got warmed up.
Jason_J
5
Tacoma, WA
check rockauto.com thay have stuff others dont
dave2575
Bay Area, Nor Cal
mostly 88
"BIGGER HAMMER!"
No problems at all when the motor is warm, from what i have read the accumulator came in a couple different styles... 1. a regular accumulator that just acts as a fuel reservoir to help feed the inline pump, 2. a fuel filter/accumulator (same thing as the first one) but with a fuel filter sitting in the bottom of the bowl. Both of them look the same and i am not sure how to tell what you have unless you screw off the bowl (not recommended, a pain in the a** to screw back on while not messing up the o-ring) I have been running without mine for almost 2 years without any problems. I hope this helps and good luck.
79F1504X400
Everett,Wa
1979
2.9L,6.6L
Yeah...good luck with that. I *thought* mine was suppose to have an accumulator.....wasted some time investigating and talking to the parts counter at my local dealer.....no luck.
NewFordOwner
Greater Puget Sound Area
2.9 liter
What you're talking about isn't an accumulator it's the fuel filter housing assembly. Has 4 ports, 2 for the fuel lines and 2 for the return. I'm assuming you've got a dual tank system, in which case it acts in a way similar to an accumulator.
is what you're looking at, and to answer your question: Yes. Check out this thread.
TerryXn9
i know this thread is old but i have an 86 as well without the dual tanks. The bowl on mine is deeper and the filter i took out was extremely dirty. The old filter and the new on do not sit all the way to the top of the housing. Would this be a accumulator then? If so i didn't see an inline filter after the high pressure pump.
