Wheel Q's?
SCAGNETTI
CT
Hey everyone! Just want to get some opinions/confirmation here before i buy. Truck is a 2003 XLT 4wd Supercab 4dr w/ 16" wheels. Tires are good, 245/75/16. The wheels not so much.
Looking to buy these: http://www.summitracing.com/parts/crr-3427712/overview/.
Have been searching on here and my head is spinning. But most info. is on 15" wheels. Just want to make sure these will fit, I also plan on running the factory lugs and center caps.
Or anyone in CT with a deal on some decent factory wheels i would also be interested. Thanks!
SCAGNETTI
CT
Thabks for the reply. But looking for a difinitive answer.
Kowboy
4
Hanover, Virginia
ONE things to consider is the center hub hole size, which appears to be 4" and I'd think that is as large as what you have on your truck now. They are just 7" wide which is very narrow IMO. You've probably got stock 8" wheels on it now. Backspacing is 4" and should be more than OK. I would think that using the stock center caps would look funny as they would stick out from the new rims surface.
SCAGNETTI
CT
Kowboy, This is the look i want. I understand that these are alot bigger than im talking about. Pic for reference. what else can i fit? Will a 16x8 look better. I dont mind a little offset. But dont want 3" of tire hanging outside the fenders.
Kowboy
4
Hanover, Virginia
6 x 8's would be fine. I've got 15 x 8's on my 2WD w/ no mud problems up the sides. I am surprised to see that the OEM center caps do work. The key to that is the rims offset. That is one bad looking truck!!
Kowboy
4
Hanover, Virginia
I think you should search wheel offset and backspacing and educate yourself on wheel measurements. Remove one of your wheels or use your spare if it's easy to get to. I would then measure the backspacing on that existing wheel. I would take measurements of how the existing wheels fit on the truck, re: measure how much more inward I could go without having tire rub. I used a 4 ft level to check the distance of my existing wheels from outside fender to the outside of the wheels lip. I then knew how much further I was willing to go outward. I'm sorry but I just wouldn't want to suggest wheels for you that may not meet w/ you expectations. I believe you will be more pleased w/ something that you figured out. There is a chart online that will convert the metric tire sizes into inches. This will assist you w/ tire choice.
don4331
1,346
Calgary, AB
5.3
Don't guess (or let other's guess for you).
My '99, I open driver's door and look at the Federal sticker.
Tires are 245/75R16; wheels are 16x7.0. That gave me baseline. Then I measured backspacing on my rims; measurement I got was 4.5". FWIW 245/75/16 is basically 31x10R16
So, I were to mount the Cragars you are suggesting on my truck with stock tires, they would be 0.5" inboard. Rim width is same so no concern about them mounting. Quick check, MY truck would have clearance.
If I wanted to mount 305/70R16s (basically 33x12R16); quick check at tirerack.com indicates 33s mount on 8"+ rim; so if I wanted bigger tires, I would need to go to the wider rim. The +12mm offset matches my stock rim so I can put the front wheel on jack and check if the 1" extra width & diameter would rub by turning wheels from lock to lock...
There appears to be a couple places clearance gets too close for comfort...
Hope this helps you.
Don
p.s. 245/75R16 fit on rim 6.5-8".
SCAGNETTI
CT
Thanks for the replies everyone. I have the 16x7 according the info. I can find on TRS and the interwebs. Think i will have to just head down to the tire shop and see what i can find out. The 8" rim would be nice to use. And maybe a different offset the factory wheels just seem very flat, no depth. Not looking to put a big tire on just better looks than my corroded mags now.
