Bronco II Seat Belt Sleeves
The Slider
Castroville, Texas
1972
Does anyone know where to get replacement seat belt plastic sleeves ( the one next to the center console w/ the release button) for the bucket seats? Mine are all cracked and I have to fight to find the seat belt to click it. I have seen some online, but they are all 12" , The ones on the Bronco I are smaller?? Has anyone used these and cut them down?
Thanks!
Chaz
mplummer08
LMC truck has them available in multiple colors. They are listed at 12" but are designed for the BII.
Sent from my SM-G892U using Tapatalk
The Slider
Castroville, Texas
1972
Mine are around 6" - 8" long.. Do they need to be cut?
IIBRONCOS
11
AZ
I got some from LMC for my stock 1988 B2 and I had to modify them more than I thought I should of had to. They are definitely universal and not designed as a bolt on replacement for the stock 1988 B2. You'll see when you get them. One of the seat belts are longer than the other, so make sure to measure before cutting the new sleeve to fit. You also may need to cut a groove in the new sleeve for a better fit. Once installed they work and look great.
