horn thing in the column I can figure out the name
Efbigdave72
Ok so I am new to ford rangers and recently I bought a 1988 ford ranger with a 2.9l v6 and the horn. Does not work because in the steering Columbia there is a part that is spring loaded to make a constant connection to the steering wheel so you can beep your horn no matter where your steering wheel is turne... And the spring loaded part is broke. It is the part that touches the copper plate in the wheel. What is the part called so I can buy one.
Sasquatch_Ryda
Forum Staff - Retired
108
Terrace, BC, Canada
Solid Axle Swap 4x4
40s
Clock spring
martin
26
St Bruno, Quebec
1991
Are you sure the horn button is not on the end of the turn signal stalk?
SenorNoob
551
Middle Tennessee
1.5" Front + 4" Rear
245-70-R16
Not in '88. That was only the very early trucks. In a way it was a better idea. Just so much harder for people to get used to.
BRUTUS_T_HOG
ASE Certified Tech
36
Rainier, OR
2.3L
Horn brush. Dealer item.
mattpresley
13
Mesa, AZ
FORD F-250
6.2
Solid Axle Swap 4x4
lol steering Columbia. :D
mattpresley
13
Mesa, AZ
FORD F-250
6.2
Solid Axle Swap 4x4
This, since you asked.
SenorNoob
551
Middle Tennessee
245-70-R16
Oh, I feel really dumb now.:icon_twisted:
Also called the sliding contact.
And I caught that "steering Columbia" as well. Got a little chuckle out of it.
