A4ld to m5od. starter wont catch, just grinds.
William87B2
Florence Al
2.9l v6
A few months ago I swapped my bad A4ld for a m5od, used a brand new 2.9 flywheel and clutch, and the old starter, well it started the first couple of times then it just started grinding, I picked up a starter under warranty and it did the same thing. It engages fine outside of the truck, so I sprayed some paint on the starter and it looked like the starter wasn't close enough to the flywheel. Ive been pushing it off everywhere I go, has anyone else had this problem, or know how to fix it?
Explorin94
Law Enforcement
Firefighter
EMT / Paramedic
Solid Axle Swap
19
Farmington Il.
4.0
The starters between the auto and the manual are different. They are clocked different at the bellhousing. You will need to go buy a starter for a manual transmission.
William87B2
Florence Al
2.9l v6
The part # is the same for the 2.9 starters
big hutch
ford
get you a starter gear for a 90 modle ford escourt it has 10 teeth $25.00 bucks advance auto parts
Mr. Tarkanian
Central KY
2.9L
When you removed the auto flexplate, did you re-use the spacer shim on the manual flywheel? If you did, that may throw off the clearance?
William87B2
Florence Al
2.9l v6
No I didnt reuse the spacer, and I will try the 10 tooth, thanks for the replies!
Strieg
U.S. Military - Active
Central California
2.9
I had (have I guess, just haven't worked on the truck in months) the same issue with my Trans swap, but I went to a.... Idr a 5 speed out of a b2, wasn't m5od. But same starter grinding issue. Guess I'll try the 10 tooth as well...
Did it work for you?
Strieg
Central California
2.9
Any word if this worked? Haven't picked up a new gear yet....
William87B2
Florence Al
2.9l v6
Yes it worked great! Sorry for the late reply.
Staff online
Today's birthdays
Shran
April Truck of The Month
