From memory, my 85 EFI Lima has two solenoids under the plastic cover.
Some replacement (aftermarket? FoMoCo?) position sensors did not give a correct bottom/top voltage. Solution as add washer or grind pintle to adjust for x.xV closed.
The solenoids are part of a 'dithering' system. One applies vacuum to feed the second (cruise?) and the other vents vacuum to atmosphere to position the EGR valve.
If no response to 'apply full vacuum' command, the sensor is noted as suspect.
EGR is not used at idle. If you have idle problems, and applying vacuum to the diaphragm makes no difference, check the diaphragm for leakage or the pintle valve for sticky. Applying vacuum at idle should cause a BIG change in idle quality, perhaps stalling.
If you have mud daubers, check that the vent solenoid with the cube of sponge rubber to filter is not plugged by nest/cocoon materials.
The FoMoCo EVTM manual is PRICELESS. I got mine when I bought the truck in Dec 84 (CA EFI emissions 'spec' that failed SMOG test @5k miles!!!!)
Anyway, in addition, the VRESVR should be a large can(plastic?) and should have all vacuum 'users' on its side of the check valve. The 'other' side is manifold vacuum.
Maybe not all, see JPG, but at least the HVAC and brake booster as noted above....
tom
