Factory fog lights 93 4x4 and wiring question
eric17mx
Guest
Can the bulbs be replaced in these or do you have to get the whole assembly?also on a set of hella 55w light do i have to wire with the relay and all that or can i just use a inline fuse and wire it to the battery and a switch? Thanks
17
mississippi
v6 3.0
which hella lights do you have? and it is to your benefit to use the relay. if you dont you risk frying your wiring. as for the factory fogs i have no idea.
Ranger44
Ford Technician
23
Illinois
FORD
4.0 OHV
I'm pretty sure the factory fog lights are sealed units, but not 100% sure on that.
Any aftermarket fog or driving lights should be wired with a realy. It's the best and safest way to do it. Don't risk damaging equipment.
If it were my truck, I'd actually run the wires for my lights into the wiring harness and into the power distribution box. Make it look like it belongs. :icon_thumby:
eric17mx
Guest
Not sure on the size they are about 5 inches im guessing also i noticed where the factory fogs go they have been replaced with some hella ones that fit, can i just go to vatozone and get some other sealer fog lamps?
17
mississippi
v6 3.0
got any pics that would help
Staff online
Members online
Shran
April Truck of The Month
