trailer brakes
--weezl--
June 2011 OTOTM Winner
Law Enforcement
OTOTM Winner
TRS Banner 2012-2015
182
hell
4.0
so i'm going to be towing a 1936 ford model 68 behind my truck, about 1000km (650miles) i have the stock class v hitch, and the stock 4 pin wiring, i'm 99% sure i'm going to have to wire up brakes, depending on what trailer i manage to get...
the uhaul one i am looking at, has surge brakes, which means i can't run a weight distributing hitch, which means i am limited to 3500lbs, which is less than what i expect the car and trailer to weigh, (it will still be under 5800lbs, which the truck is rated at) the hitch is classed at 6000 weight distributing, and 3500 weight carrying... if i go with electronic brakes, i can run the weight distributing hitch, but will need to wire a controller...
ANYWAYS, how hard is a brake controller to wire? i'm thinking that with a 14 hour trip, (what we figure it will take, with the load) the battery won't last on it's own, and i will need to hook up a charging system... so is it more than a few wires to the back for charging, and 1 wire for brake control?
Sasquatch_Ryda
Ford Technician
OTOTM Winner
Solid Axle Swap
Forum Staff - Retired
108
Terrace, BC, Canada
Engine Type
4.0L
2WD / 4WD
Solid Axle Swap 4x4
40s
You use the 4 pin wiring for your lights/signals/brake lights.
You then need to connect battery power to a 20 amp circuit breaker, then run that power wire inside to where you will mount your brake controller. You Mount your brake controller, ground it, attach your power wire to it, run the wire from the brake controller to your brake on/off switch at the brake pedal, and run your brake power out to the back of the truck along the inside of the drivers frame rail.
For the charge line you will run another battery power wire wire to a 30 amp circuit breaker, from the circuit breaker to a solenoid which will be triggered by ignition power. So when the ignition is on you have power going to your trailer. You then run your wire to the back of the truck again like before.
I used 10 gauge wire for both the brake and charge wiring.
--weezl--
Law Enforcement
OTOTM Winner
182
hell
4.0
ok cool, that doesn't sound too difficult... next set of questions,
1) is there any difference in the INSTALL of the time delay and inertia style controllers? i know there is a significant difference in how they work, and setting them up...
2) are the brakes powered by the battery on the trailer and actuated by the controller, or is all of the power to the brakes directly from the controller? (trying to understand the necessity of the charging)
Sasquatch_Ryda
Ford Technician
OTOTM Winner
Solid Axle Swap
108
Terrace, BC, Canada
Engine Type
4.0L
2WD / 4WD
Solid Axle Swap 4x4
40s
No, the install is the same. I recently just purchased a 24 foot travel trailer (4100lbs dry weight) to tow behind my 05 sport trac. I went with an inertia style brake controller. I find them to be much better than the time delay style. With a time delay controller, every time you release the brake pedal and re apply it there is a delay in when the brakes on the trailer start to work. With the inertia style the trailer instantly starts to slow down, but only as fast as the tow vehicle is slowing down allowing more control and no brake lock up. I went with the Tekonsha Prodigy P2 and love it so far.
The brakes get their power right from the brake controller. The controller controls how much amperage is being sent to the magnets in the electric brakes on the trailer. The charge line is there simply to charge the battery(s) that supply power to accessories on the trailer like interior lights/power jacks etc.
--weezl--
Law Enforcement
OTOTM Winner
182
hell
4.0
perfect, thanks for the help, i was leaning towards the inertia style, because it seems much more advanced plus i dont' have to wait a couple seconds for trailer brakes, if i have an emergency stop...
the trailer i will be pulling is a flatdeck car trailer and shouldn't have any lights on it (other than running lights of course) and the only accessory that it might have is a winch, which i kind of doubt... so i shouldn't have to worry about a charging system then eh?
thanks again for your help! i will be stopping in at my local custom truck parts location tomorrow morning on the way home from work to see what they've got for me!
Sasquatch_Ryda
Ford Technician
OTOTM Winner
Solid Axle Swap
108
Terrace, BC, Canada
Engine Type
4.0L
2WD / 4WD
Solid Axle Swap 4x4
40s
Doesn't sound like you will have a need for the charge line then, but it might be nice for future use possibly.
Oh and if you want I can get pictures of my install if you need ideas of where to mount stuff.
--weezl--
Law Enforcement
OTOTM Winner
182
hell
4.0
woudn't hurt, i'm sure everyone would love to have a how to:
i think i should be able to figure it out, and i don't know how similar it would be between the st and the ranger though...
if you don't end up making one, i'll do one when i make my install
martin
26
St Bruno, Quebec
1991
ford
The charge wire is for the battery on the trailer (if it has one), There's usually a breakaway switch on the front of the trailer with a cable attached to it that seperates and applies the brakes (needs power for brakes) in the event the trailer gets away from the tow vehicle. You probably don't need to worry about it anyway.
--weezl--
Law Enforcement
OTOTM Winner
182
hell
4.0
i think it will be one of those we will see how much time i have, type things... if i get around to running that wire, i will, but who knows...
are trailers all wired (pin out) the same? of course there is going to be people who screw around like my friend did with his trailer, and move all the wires around so that if anyone tried to steal his trailer, it would blow all the fuses and the brakes would lock up from the constant power
TomB1269
3
Capital District NY
2002, 2005, & 2
All Fords
3.0L/4.2L/5.4L3V
For the most part they are standard, with the possible exception on the constant hot pin and the reverse light pin. If you are installing a brake controller, you may want to look at a multi-tow receptical. Hoppy makes one that you just plug in your 4 pin and then wire up the others. With a multi-tow you would have a 7 pin and a 4 pin at all time without the need for an adaptor.
As for the constant hot power, you going to run a wire from the engine to the rear bumper for the brakes just tape a second wire on and pull the 2 together.
PS: msot brake controllers suggest direct to battery for the power source. that way there is limited chance of lossing trailer brake power.
yyc_tbird_sc
Firefighter
EMT / Paramedic
6
Calgary, Alberta
I think you should check this again. If it's a ranger, I've never seen one with that kind of payload capacity before. If you're thinking that the GVWR rating of 5800lbs is what you can put on a trailer...wrong. GVWR is the total weight of the truck and anything attached to it, including a trailer. Not trying to be rude, just seen way too many bad things happen when vehicles are overloaded.
I must complemend you though, at least you are doing the right thing with wiring up for trailer brakes and everything. I seen a trailer pulled by a jeep YJ the other day where the owner had just disabled the brakes and was using just the standard 4 pin wiring...
Sasquatch_Ryda
Ford Technician
OTOTM Winner
Solid Axle Swap
108
Terrace, BC, Canada
Engine Type
4.0L
2WD / 4WD
Solid Axle Swap 4x4
40s
Agreed. That is the weight rating on the hitch, not of the truck you are looking at.
Will
Forum Staff Member
514
Gnaw Bone, Indiana
Toyota
4.0
The combined weight of the truck and trailer is the GCWR, which is about 9,500# for a 4.0 auto Ranger. The maximum tow rating for the same Ranger is around 5,800#. That's the weight of an empty Ranger subtracted from that 9,500#. Everything loaded into that Ranger reduces the 5,800#--a 200# passenger brings it down to 5,600# tow capacity, for instance.
The GVWR has nothing at all to do with towing, unless you have so much tongue weight that you overload the rear axle.
I think that old Ford is about 2,500# and a standard 2-axle car hauler is around 2,000#. You're over 3,500#, as you know. Ford's towing guide says a Ranger needs a weight-distributing hitch for over 3,500# and 350# tongue weight, as you know. I've never towed that much with a Ranger but they aren't sprung too strongly so I'm guessing tongue weights over 350# push the rear down too far and throw things out of whack. I like tongue weight so I wouldn't unload the rear axle too much with the trailer out weighing the truck by 1,000#. I don't like getting the ass end of the truck pushed sideways.
--weezl--
Law Enforcement
OTOTM Winner
182
hell
4.0
Will, i got the first half of that, you kinda lost me in the second half... i'm not TOO worried about how hard the drive is going to be, it's in the air if i am going to pull it with my ranger or my dad's f-150, there is other factors, not just the vehicle abilities... if we use my dad's f-150, he's driving his truck next to me in my truck, and it's going to be a 2000 km (1300mile) round trip EXTRA, plus we can't switch off drivers... if we take 1 vehicle (mine) back, it will be a slow, steady drive back, maybe doing 80km/h (50mph)
the other thing is i'm now debating on bringing my motorcycle out with me, which is another 518lbs fully loaded... i know the manuals are rated at lower, but looking into it, it is NOT because the ranger manual transmissions are crap, as i was once told, it is because ford compensates for people's lack of skill in driving a manual, riding the clutch and shifting quickly, while towing, and it's not that it won't do it, it's just open to much more wear if not done properly
i should just put it this way, the biggest thing i'm worried about, is laws... if i get pulled over, what am i going to get hit for? what numbers in my door am i going to need to make sure i am below (if any) i don't mean to be thick headed, but i don't have any worry about my truck's ability (that being said i do NOT think it is in any way an SD or bullet proof)
the other option i was looking at, was buying a class IV hitch for my truck for 175, installing it, and running the uhaul trailer, which i then don't have to worry about brakes or leveling hitches (5000 weight carrying 10000 distribution) and have the trailer's total weight about 4800lbs (not compensating for the lack of floor boards and severely deteriorated condition of the 36)
thoughts? yyc, thanks for your input, you in no way came off as rude :icon_thumby:
yyc_tbird_sc
Firefighter
EMT / Paramedic
6
Calgary, Alberta
My bad, I mixed up GVWR and GCWR...LOL I was at work when I posted this and it's been non stop for a while now.
I don't think you'll have a problem if you follow whatever weight rating your truck has on the info sticker and keep the total weight as close to, or lower as possible. Keep your trailer legal as well (brakes, lights, tire condition, registration, etc). If you give the local authorities a reason to suspect you, then you'll be hassled.
Just because you can buy a hitch rated for 10,000lbs doesn't mean your truck can haul that. You will still have to worry about levelling hitches and trailer brakes.
I would take your truck to a shop that specializes in towing/trailers and talk to them about exactly what you can do. If they tell you that you can tow whatever the hitch is rated for....exit quickly and go find another shop.
Staff online
Members online
Kirby N.
March Truck of The Month
