Are these the correct parking brake cables???
Canuck4x4
New Brunswick
4.0
...I recently picked up a rear left and right parking brake cables for my 2003 xlt 4x4 " extended cab " from a discount parts store, and they are not holding right. With the parking brake on if you apply a bit of gas the truck will lurch ahead. In guessing they gave me cables for a regular cab.
...I went to the ford dealer and they told me I need a " Brca 40 and Brca 11. I looked it up when I got home and it sais these are for a 04 05 + ranger. Will these fit on my 03 extended cab?
Thanks
holyford86
Some guy with a problem
RBV's on Boost
GMRS Radio License
610
Plattsburgh, NY
many
4.0
2WD / 4WD
33x12.50R15
sounds like you need to adjust your brakes up, if your pedal goes to the floor and you feel very little resistance, then this is probably the case.
adsm08
Senior Master Grease Monkey
Ford Technician
3,613
Dillsburg PA
Engine Type
4.0
2WD / 4WD
31X10.50X15
I agree with Holy. Regular cab cables are the same at the axle, and if they were wrong they'd be way too short and just wouldn't fit.
modelageek
14
Boston, MA
Engine Type
4.0
2WD / 4WD
Was the issue there before? Maybe the 2 other old cables stretched?
Sent from my SM-J320V using Tapatalk
Staff online
Shran
April Truck of The Month
