Master cylinder question for explorer 8.8 swap
ish474
Uniontown Pa
5.0
Is it nesesary to change the master cylinder when you do the 8.8 explorer swap? I'm sure it's covered somewhere else but I didn't find a clear answer.
chvlfrk
December 2010 STOTM Winner
MTOTM Winner
31
Niota, TN
Ranger XLT 5.0L
Engine Type
V8
5.0L
235/70R15 front / 275/60R15 rear
Don't think so.............
I changed nothin on my 94 when I swapped in the 92 Explorer axle 3 yrs ago or when I put in the 98 Explorer disc braked axle last year............no problems here!
bobbywalter
TRS Technical Staff
TRS Event Staff
TRS Technical Advisor
TRS Banner 2012-2015
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
Engine Type
V8
BIGGER
2WD / 4WD
sawzall?
it is easier to fix and understand than "her"
if it is disk brake you will want to put the disk master on but you can get away with it for a spell.
4x4junkie
Forum Staff Member
583
So. Calif (SFV)
Bronco II
Engine Type
2.9 V6
2.9L V6
2WD / 4WD
35x12.50R15
My BII has the stock master, seems to be fine ('99 Ex 8.8)
AKBroncoII
The brake bias is different from a disk/drum master to a disk/disk master. I wouldn't run a disk/drum master with disk braked rear.
mjonesjr
I dance with the Devil...
Firefighter
Forum Staff - Retired
13
Salem, IN
as long as your truck doesn't have ABS, then the master cylinder will be fine.....
ish474
Uniontown Pa
5.0
Thanls for all the help. I'm going to go with the ranger master cylinder for now but I will upgrade later. I'm going to run bigger front brakes also but for now I need to make this thing drive under it's own power.
bdavis
Ranger
I have a '93 Supercab with the 4.0 and rear ABS. If I swap in the Explorer disk brake rear, how big of a pain is it to swap in the disk brake master cylinder?
engdept
5
Charlestown, IN
2.9
You wont need too.
Yellowsplash
U.S. Military - Active
11
Morgantown, WV
The master cylinders are the same (in relation to the same year vehicle) as long as your ranger had ABS. ex. Since you have a 93, yours will be the same as a 93 explorer.
Where the problem lies is that ford used a different master on the newer vehicles (95-97 and again in 98) so if your swapping in an exploder 8.8 with disks (95 up), the masters would be different. While you can use the existing master, I myself would look into upgrading to the newer master. You should be able to swap them out. Im unaware of any mounting differences other than maybe tubing nut size, etc.
The other difference is the proportioning valve is different and can be swapped over, but most people dont mess with it, and with the amount of people running the exploder 8.8, I havent heard of any problems due to this.
2004xlmiller
March 2013 OTOTM Winner
OTOTM Winner
3
Sacramento
gonna bump an old thread here.. i did a mustang disc brake swap on my ranger, so not an expo 8.8. my truck does have ABS, and the pedal gets a little soft and doesnt respond the way it should when braking. an expo master should work and fix this, but what years are best to look for? direct swap nothing else needs to be changed?
kryptonitecb
19
Fort Worth, TX
4.0
I would take a guess and say abs will not work right without the proper master cylinder but then I don't have abs either. Most guys takes it out as it interferes with offroading and other aspects of truck upgrades.
Any master cylinder from a 4 wheel disk explorer will fix the soft pedal issue.
Sent from the road while ignoring traffic
2004xlmiller
OTOTM Winner
3
Sacramento
if thats the case after i swap in the expo master (tonight) ill just pull the fuse for the ABS.
kryptonitecb
19
Fort Worth, TX
4.0
Do some searching cause I'm not to sure about my answer.
adsm08
Senior Master Grease Monkey
Ford Technician
3,613
Dillsburg PA
Engine Type
4.0
2WD / 4WD
31X10.50X15
Watch out opening the system above the ABS module. Air can get trapped in it and doesn't bleed out normally. If you want to delete the ABS plumb around the module. You need to keep the ECU intact and functioning because the speedo signal runs through it.
Staff online
Members online
Shran
April Truck of The Month
