Code Check-fuel/vacuum/brake issues
F350CrewCab
WV
2.9
2WD / 4WD
Old School Ethics
Gas in brake booster, hard pedal-all new brakes/kits-new master cylinder and booster, new fuel pressure regulator. We'll see if I did this right. Analog check: 1 sweep, pause, 1 sweep, pause, 1 sweep, bigger pause, 1 sweep, bigger pause, 9 sweeps, pause, 5 sweeps, bigger pause, 9 sweeps, pause, 5 sweeps, nothing else. CEL check: flash, pause, flash, pause, flash, pause, flash, pause, flash, bigger pause, flash, bigger pause, 9 flashes, pause, 5 flashes, bigger pause, 9 flashes, pause, 5 flashes, nothing else. I take it there is a ground issue with the fuel pump but it runs, and not all the time unless engine is running. Yeah, I found out when I was working on the sending unit. Would somebody please try to enlighten me. I'm trying to learn as an old dog here but never got involved with this computer type stuff. Dan
Note: KOEO on tests
adsm08
Senior Master Grease Monkey
Ford Technician
3,613
Dillsburg PA
Engine Type
4.0
2WD / 4WD
31X10.50X15
The codes are you getting are telling you there was, at one time, a problem with the fuel pump circuit. The second set where you get the 95 is for memory codes, which means the problem was there at one time, but isn't right now.
The 111 is a system pass code, meaning it checked everything it was supposed to and it didn't find any problems.
F350CrewCab
WV
2.9
2WD / 4WD
Old School Ethics
What does gas in the booster indicate? Only been on for about 100 miles. With hard pedal, have I blown another booster? Just replaced the FPR yesterday. Drove to work, about 1/4 mile and back, then pedal became hard.
adsm08
Ford Technician
3,613
Dillsburg PA
Engine Type
4.0
2WD / 4WD
31X10.50X15
Gas in the booster kills it. The gas was coming from the failed FPR, and yes, you probably damaged this booster.
F350CrewCab
WV
2.9
2WD / 4WD
Old School Ethics
Oh well, Sure do appreciate the info. Enjoyed reading about your projects.
F350CrewCab
WV
2.9
2WD / 4WD
Old School Ethics
Booster
You knew ya was right didn't ya. Booster was definitely bad. Feels real good all around pretty much. Should have changed the FPR when the rough idle and stall situations continued along with blowing 2 old boosters. Still got alot to go through but I'll get there. Thanks for the help.
Staff online
Shran
April Truck of The Month
